Thank you for reaching out to us.
Before I can help you with your question, could you help me know if by creating a surface set, does this mean that your main goal is to group several surfaces under one set? Or else, do you want to create a surface in an existing or new part?
Thank you for your fast response.
For your information, for the time being we don’t have the API to group several surfaces into a surface set.
However, one workaround that I can suggest is to move the surfaces that you want to group to a new part, rename the part as per desired and finally merge the new part with the original part.
API that you can use:
trimatic.move_to_part
trimatic.merge
In the example below, I have moved surface_a and surface_b from part1 into a new part, rename the new part as ‘surface_set1’, merge this part with part1, and rename the resulting part as ‘part1’.
before:
after:
Please let me know if you need further clarification on how to do this operation.
Hope this helps!
