Many workflows require the use of multiple tools from Mimics and 3-matic. With scripting is possible to automate such workflows and use tools from both software packages.
This tutorial shows how to continue the workflow in 3-matic while working in Mimics. The results of 3-matic are returned to Mimics and the script continues in Mimics. You can have the scripts of 3-matic and Mimics in different *.py files or in the same file. For this tutorial a single-file script approach is selected.
The Mimics project Heart.mcs from C:\MedData\DemoFiles is used. 3-matic is used for some advanced operations that are not available in Mimics, consequently there is no 3-matic project loaded.
import os
import subprocess
import sys
# One script is used for both Mimics and 3-matic.
# For that reason we have to check if we are in Mimics or in 3-matic
try:
import trimatic
except:
in_3matic = False
else:
in_3matic = True
SHARED_OBJ = "Union"
# If True we are in Mimics
if not in_3matic:
# Open Heart.mcs Mimics project
path = r"C:\MedData\DemoFiles\Heart.mcs"
mimics.file.open_project(path)
# Find the masks of interest
masks_names = ["LA", "LV", "Aorta"]
masks = []
for m in masks_names:
mask = mimics.data.masks.find(m)
if mask:
print("Mask " + m + " is present.")
masks.append(mask)
# Unite masks
if len(masks) == 3:
un1 = mimics.segment.boolean_operations(masks[0], masks[1], "Unite")
union = mimics.segment.boolean_operations(un1, masks[2], "Unite")
union.name = SHARED_OBJ
# Create the Part of the Union mask
union_part = mimics.segment.calculate_part(union)
union_part.name = SHARED_OBJ
# Export the Union Part in the location of the script
root_path_of_script = os.path.split(os.path.abspath(__file__))[0]
path_of_stl = os.path.join(root_path_of_script, union_part.name + ".stl")
mimics.file.export_part(union_part, path_of_stl)
with open(os.path.join(os.path.split(__file__)[0], "my_temp.txt"), "w") as f:
f.write("File is created!\n")
# Prepare to run 3-matic
trimatic = mimics.file.get_path_to_3matic()
command = trimatic
args = ("-run_script", __file__, path_of_stl, f.name)
process = subprocess.Popen((command,) + args, shell=False, stdout=subprocess.PIPE)
process.wait()
with open(f.name, "r")as f:
lines = f.readlines()
os.remove(f.name)
for i in range(2):
mimics.file.import_stl(lines[i + 1].strip())
else:
print("Please check if a mask is missing! Three masks are required.")
# If True we are in 3-matic
else:
path_of_stl = sys.argv[1]
f = sys.argv[2]
trimatic.import_part_stl(path_of_stl)
part = trimatic.find_parts(SHARED_OBJ)
if part:
plane = trimatic.create_plane_fit(part[0])
cut_parts = trimatic.cut(part[0], plane)
exp = trimatic.export_stl_ascii(cut_parts, os.path.split(os.path.abspath(__file__))[0])
with open(f, "a") as f:
f.write(exp[0] + "\n")
f.write(exp[1])
print("To continue please close 3-matic!")
