I’m using an SSM to produce a large number of measurements and I’d like the script to output a chart of some kind to visually represent the measurement distribution. A histogram like the one in the 3-Matic SSM Properties interface would be great. Is this possible in 3-Matic? If so, how?
If it’s not possible to script a chart like the one described above, is there some way to export the data to Excel or Matlab?
If it’s an official analysis object in 3-matic (like a wall thickness analysis), you can use the “export analysis” function. However, this probably won’t work in this example.
