Script to Read Excel Data into 3-Matic via Pandas ‘Dataframe’ object
A Dataframe object is a multi-dimensional table-like data structure (a multi-dimensional array)
Your data must be in a simple multiple array format with only column and row labels, 2D excel data.
See the example below:
Model X1 Y2 Z3 X1 Y2 Z3 NX NY NZ
R1 05 10 15 31 15 04 08 04 02
R2 01 45 02 03 05 04 08 06 04
R3 02 05 04 45 05 06 05 04 50
Once the data is imported as a dataframe object, row numbers will be created to iterate through each model
0 R1 05 10 15 31 15 04 08 04 02
1 R2 01 45 02 03 05 04 08 06 04
2 R3 02 05 04 45 05 06 05 04 50
You can follow the Pandas ‘Dataframe’ documentation for maniuplating the imported data.
This link below on Realpython.com is very helpful
The pandas DataFrame: Make Working With Data Delightful – Real Python.
#Import 3-matic and pandas libraries
import trimatic
import pandas as pd
#Create a new project
trimatic.file.new_project()
#***Must be changed for your script***
#The path where you excel data is located
path = r'C:\Users\user\Excel Dataframes Template.xlsx'
#Creating the Datafram object using the pandas 'read_excel' function and the excel file located at the
windows path
df = pd.read_excel(path)
#Loop that interates along length of dataframe (# of rows)
#This specific demo data contains information to create 2 points, a plane (using normal and origin
data), and a measurement between the two points.
for i in range(len(df)):
#Iterating through the first column to extract the model name for each point coordinate set
name = df.Model_ID[i]
#Point 1 Creation
x_cord = df.P1_X[i]
y_cord = df.P1_Y[i]
z_cord = df.P1_Z[i]
P1_cords = [x_cord,y_cord,z_cord]
P1 = trimatic.create_point(P1_cords)
P1.name = f'{name} Point 1'
#Point 2 (Origin) Creation
x_cord = df.O1_X[i]
y_cord = df.O1_Y[i]
z_cord = df.O1_Z[i]
O1_cords = [x_cord,y_cord,z_cord]
O1 = trimatic.create_point(O1_cords)
O1.name = f'{name} Point 2 Origin'
#Plane Creation
#Normal coordinates
x_cord = df.N_X[i]
y_cord = df.N_Y[i]
z_cord = df.N_Z[i]
n_cords = [x_cord,y_cord,z_cord]
plane = trimatic.create_plane_normal_origin(normal=n_cords,origin=O1_cords)
plane.name = f'{name} Plane'
#Create distance measurement and name based on model ID
distance = trimatic.create_distance_measurement(P1, O1)
distance.name = f'{name} {P1.name} to {O1.name} Distance'
#Group points, plane and distance measurement into groups based on Model ID
trimatic.create_group(entities=[P1, O1, plane, distance],name=name)
