Loft with tangent direction
Hello! I’ve been working on a 3matic script to generate lofted parts using two given surfaces. I noticed that the “direction” parameter is available in the Loft tool through the UI, but it doesn’t appear to be accessible via the MIS API.
My questions are:
  • Is there currently any way to replicate this behavior using MIS scripting?
  • And by any chance, is this expected to change or be included in future scripting updates?
Thanks in advance.
Hi Agustin,
We update the API every year, we can add it as a suggestion for future releases. As a workaround, you could try to use the ‘sweep loft’ functionality instead.
Hope this helps for now. If you still have issues, please contact your local Application Engineer to help over a call.
Thank you!
Zack
