Not applicable
I made a script that allows me to perform a transformation on an object using pre-defined points where the object is used as moving entity in n-points registration function. I want to use this function from the scripting library where I can visibly see it. But unfortunately there is an arrow pointing next to it which says “Not applicable”. How can I fix this so I can apply this script. This script is a similar version of another script which worked fine. So it should have nothing to do with the content of the script.
Thanks in advance
Hi Simon,
I can’t seem to replicate the issue. Could you provide some screenshots for extra context at which stage/part this issue happened?
Imanina
