Renaming tool (Mimics 21.0)
Hi all!
I have created a script that allows you to easily rename masks in any Mimics project. The idea is that you can create (and modify) a list of names and even associate colors to those. To rename a mask, simply select the mask in the PM-tab and then click on the proper name in the list. The name (and the color if specified) of the mask will be adapted!
Also available on GitHub with a short guide: https://github.com/clementdum/Renaming-tool
# Import packages
import mimics
import pickle
import os.path
import numpy as np
import tkinter as tk
from tkinter.colorchooser import *
# Function needed later in the script to transform a color value from an hex format to a rgb format
def hex_to_rgb(value):
	value = value.lstrip('#')
	lv = len(value)
	return tuple(int(value[i:i + lv // 3], 16) for i in range(0, lv, lv // 3))
# path to this script file
pathtofile =  os.path.dirname(sys.argv[0]) + r"\data_renaming.p"
# creation of the class RenamingTool in which the tool interface will be described
class RenamingTool:
	def __init__(self, master):
		self.master = master
		self.opened = 0
		master.title = "Renaming Tool"
		frame_liste = tk.Frame(master)
		frame_liste.grid(row = 0, column = 0)
		class Name:
			def __init__(self, name, name_color):
				self.name = name
				self.name_color = name_color
		# when opening the tool, it is checked if a file with a list of names already exist. If not, the tool is open with a list of default names.
		file_exist = os.path.isfile(pathtofile)
		if file_exist:
			data = pickle.load(open(pathtofile, 'rb'))
			liste_names = data[0]
			liste_colors = data[1]
		else:
			liste_names = ["Right Heart", "Left Heart", "Bone", "Stent"]  # Default list of names when opening the tool.
			liste_colors = ["","","",""]
		list_name = tk.Listbox(frame_liste, selectmode = tk.SINGLE, activestyle = "dotbox", selectbackground = "white", selectforeground = "black")
		list_name.pack()
		ind = 0
		for i in liste_names:
			list_name.insert(tk.END, "  " + i)
		for i in liste_colors:
			if i != '':
				list_name.itemconfig(ind, {'bg': i})
				list_name.itemconfig(ind, {'selectbackground': i})
			ind = ind + 1
		def change_name(event):
			if self.opened == 0:
				new_name_index = list_name.curselection()
				new_name = list_name.get(new_name_index[0])
				color = list_name.itemcget(new_name_index[0], "bg")
				if color != "":
					color_rgb = np.divide(hex_to_rgb(color),255)
					colour = tuple(color_rgb)
				for i in mimics.data.masks:
					if i.selected == True:
						i.name = new_name
						if color != "":
							i.color = (float(colour[0]), float(colour[1]), float(colour[2]))
		def open_modify_window():
			frame_modification.grid(row = 0, column = 1)
			button_modify.config(state = 'disabled')
			self.opened = 1
		def close_modify_window():
			frame_modification.grid_forget()
			button_modify.config(state='normal')
			data = [liste_names, liste_colors]
			pickle.dump(data, open(pathtofile, 'wb'))
			self.opened = 0
		################ Frame modification #######################################################
		frame_modification = tk.Frame(master)
		def add_name():
			new_name = entry.get()
			list_name.insert(tk.END, "  " + new_name)
			liste_names.append(new_name)
			liste_colors.append("")
			entry.delete(0, tk.END)
		def delete_name():
			selection = list_name.curselection()
			del liste_names[selection[0]]
			del liste_colors[selection[0]]
			list_name.delete(selection)
		def getColor():
			color = askcolor()
			list_name.itemconfig(index[0], {'bg': color[1]})
			list_name.itemconfig(index[0], {'selectbackground': color[1]})
			liste_colors[index[0]] = color[1]
		entry = tk.Entry(frame_modification)
		entry.grid(row = 0, column = 0)
		button_add = tk.Button(frame_modification, text = "Add", command = add_name)
		button_add.grid(row = 0, column = 1)
		button_delete = tk.Button(frame_modification, text = "Delete", command = delete_name)
		button_delete.grid(row = 1, column = 0, columnspan = 2)
		button_color = tk.Button(frame_modification, text="Modify Color", command=getColor)
		button_color.grid(row = 2, column = 0, columnspan = 2)
		button_close = tk.Button(frame_modification, text="Ok", command=close_modify_window)
		button_close.grid(row=3, column=0, columnspan = 2)
		button_modify = tk.Button(frame_liste, text = "Modify the list", command = open_modify_window)
		button_modify.pack()
		list_name.bind('<<ListboxSelect>>', change_name)
root = tk.Tk()
renaming_tool = RenamingTool(root)
root.wm_attributes("-topmost", 1)
root.mainloop()
