This scripts will compare two objects and give a result of whether they are matching or not in terms of surface area, volume, number of nodes, number of triangles, whether the xyz coordinates of each node are the same as the nodes with the same index in the other part, and whether each triangle is referring to the same node number. This functionality is especially useful when setting up a validation framework. It works on 3-matic 12, 13, and 14.
Credits to Kristof Godelaine for this script.
