Hi Rob,
Unfortunately, the ‘mimics’ library does not have a direct method to convert a Sphere directly into a mask.
To convert a geometric object like a Sphere into a mask without direct user interaction using the ‘mimics’ library, you can follow a workaround approach by creating a temporary Part from the Sphere and then converting that Part into a mask.
This workaround allows you to indirectly convert a Sphere (or any other geometric object) into a mask using the ‘mimics’ library in Python. While this method involves creating an intermediate Part object, it provides a way to achieve the desired result programmatically without user interaction.
So, this method involves a multi-step process. Here’s a step-by-step guide using Python:
Step 1: Create a Part from the Sphere:
You can create a Part representing the Sphere by defining its geometry (center and radius) and then converting it to a Part object.
import mimics
def create_sphere_part(center, radius):
# Create a new empty part
part = mimics.Part()
# Add a sphere to the part
sphere = mimics.Sphere(center=center, radius=radius)
part.add_geometry(sphere)
return part
Step 2: Convert the Part to a Mask:
Once you have the Part representing the Sphere, you can use the ‘calculate_mask_from_part’ method to convert it into a mask.
def part_to_mask(part, resolution=1.0):
# Calculate mask from the part
mask = mimics.segment.calculate_mask_from_part(part, resolution=resolution)
return mask
Putting it together:
Now, you can combine these functions to create a mask from a Sphere object:
# Define the parameters for the sphere
sphere_center = (0, 0, 0)
sphere_radius = 10
# Create a Part from the Sphere
sphere_part = create_sphere_part(sphere_center, sphere_radius)
# Convert the Part to a Mask
mask = part_to_mask(sphere_part, resolution=1.0)
# Now you can use the ‘mask’ object as needed
Notes:
· Adjust the ‘sphere_center’ and ‘sphere_radius’ parameters according to your specific requirements.
· The ‘resolution’ parameter in ‘part_to_mask’ controls the voxel size of the resulting mask. Lower resolution values yield higher detail but larger file sizes.
Ensure that you have the ‘mimics’ library installed and configured correctly in your Python environment for these functions to work.
I hope I’ve helped.
