Moving meshes between 3matic and Mimics
Hi Nathan,
Great workaround, thanks for sharing! As for the error above, I’m not sure why it’s referring to a tuple, but I am able to reproduce the same error if I don’t have any images loaded. Did you have any active images when you ran that code? Normally it should export all objects linked to the image stack you pass.
Julien
