For this tutorial the Mimics project Heart.mcs from C:\MedData\DemoFiles will be used.
The tutorial shows how to prepare for applying the CT heart segmentation tool. A series of function calls is created and controls the script. One function is created for each operation that will be performed. The main operations are thresholding, landmarking, calculation of CT heart segmentation masks and calculation of 3D parts. Appropriate naming is used for the respective functions.
import mimics
# Import the numpy library that is useful for some operations
try:
import numpy as np # First need to install numpy package for Python. Type pip install numpy in your cmd
except ImportError as ie:
print("================================================================")
print("=== The 3rd party Python package 'numpy' is not installed! ===")
print("=== To install it, use 'pip install numpy' in your cmd! ===")
raise
# Define a shortcut
md = mimics.data
# Constants declaration
MASK_LEFT = "Left Heart"
MASK_RIGHT = "Right Heart"
LANDMARKS = (
"RA", "RA",
"LA", "LA",
"LV", "LV",
"RV", "RV",
"AO", "AO",
"PA", "PA",
SEED_RADIUS = dict(
RA=10.0,
LA=10.0,
LV=10.0,
RV=10.0,
AO=8.0,
PA=8.0,
SEED_COLOR = dict(
RA=(0, 255, 255),
LA=(255, 0, 255),
LV=(255, 205, 205),
RV=(145, 112, 255),
AO=(255, 0, 0),
PA=(0, 0, 255),
MASKS = ("RA", "LA", "LV", "RV", "AO", "PA")
def activate_thresholding(mask_name: str):
m = mimics.segment.activate_thresholding()
m.name = mask_name
return
def indicate_landmark(pid: int):
pdef = LANDMARKS[pid]
try:
coords = mimics.indicate_coordinate(message="Indicate {} ".format(pdef),
confirm=False, show_message_box=True)
except InterruptedError:
return False
mimics.view.navigate_to(coords)
pnt = mimics.analyze.create_sphere_center_radius(coords, SEED_RADIUS[pdef.split()[0]])
pnt.name = pdef
pnt.color = tuple(np.array(SEED_COLOR[pdef.split()[0]]) / 255)
return
def calc_ct_heart():
left_heart = md.masks.find(MASK_LEFT)
right_heart = md.masks.find(MASK_RIGHT)
seeds = []
for p in md.spheres:
if p.name in LANDMARKS:
seeds.append(p)
mimics.segment.calculate_ct_heart_from_mask(left_heart, right_heart, seed_points=seeds)
for p in md.masks:
if p.name in MASKS:
p.color = tuple(np.array(SEED_COLOR[p.name.split()[0]]) / 255)
return
def create_3d_parts():
for p in md.masks:
par = mimics.segment.calculate_part(p, "Medium")
par.name = p.name
return
def main():
"""Main function."""
# Open Heart.mcs project
input_dir = r'C:\MedData\DemoFiles\Heart.mcs'
mimics.file.open_project(input_dir)
# Create masks for the left and right parts of the heart
activate_thresholding(MASK_LEFT)
activate_thresholding(MASK_RIGHT)
# Indicate the landmarking
for l in LANDMARKS:
indicate_landmark(LANDMARKS.index(l))
# Perform CT heart segmentation
calc_ct_heart()
# Create of the 3D parts
create_3d_parts()
if __name__ == '__main__':
main()
