In this tutorial some basic segmentation, landmarking and measurements operations are illustrated on the project Shoulder.mcs from C:\MedData\DemoFiles .
# Tutorial: Landmarking the shoulder and perform measurements
# Open the project
mimics.file.open_project(r'C:\MedData\DemoFiles\Shoulder.mcs')
# Create an empty mask
mask_a = mimics.segment.create_mask()
# Perform thresholding with selected min and max values
mimics.segment.threshold(mask=mask_a, threshold_min=1250, threshold_max=2800) # thresholds are set in gray values
mask_a.name = "Shoulder"
# Create a point that will be used fot the region growing operation
point_1 = mimics.analyze.indicate_point(title="Region growing point",
message="Please indicate a point on the part of interest")
# Region growing. The original mask is preserved
mask_b = mimics.segment.region_grow(point=point_1, input_mask=mask_a, target_mask=None, slice_type="Axial",
keep_original_mask=True)
mimics.data.points.delete(point_1)
mask_b.name = "Segmented shoulder"
# Calculation of the 3D part
part = mimics.segment.calculate_part(mask=mimics.data.masks.find("Segmented shoulder"), quality="High")
# Set the anatomical landmarks of the shoulder
anatomical_landmarks = ["Acromion", "Coracoid process", "Humerus"]
for point in anatomical_landmarks:
p = mimics.analyze.indicate_point(title=point, message="Please indicate a point on the {}".format(point))
p.name = point
# Create distance measurement between coracoid & acromion and humerus
m = mimics.measure.create_distance_measurement(point1=mimics.data.points.find("Acromion").coordinates,
point2=mimics.data.points.find("Humerus").coordinates)
m.name = "Acromion-Humerus"
m = mimics.measure.create_distance_measurement(point1=mimics.data.points.find("Coracoid process").coordinates,
m.name = "Coracoid process-Humerus"
# Create Angle measurement between the three landmarks in the shoulder area
mimics.measure.create_angle_measurement(point1=mimics.data.points.find("Acromion").coordinates,
point2=mimics.data.points.find("Humerus").coordinates,
point3=mimics.data.points.find("Coracoid process").coordinates)
# Save the project
mimics.file.save_project()
