In this tutorial basic operations to the lower limb are illustrated. The right femur and the pelvis are segmented and basic operations are performed to the masks and the 3D parts.
# Tutorial: Perform segmentation and operations to the Hip.mcs. Calculate and export STL
# Open the project
mimics.file.open_project(r'C:\MedData\DemoFiles\Hip.mcs')
# Create an empty mask
mask_a = mimics.segment.create_mask()
mask_a.name = "Lower limb"
# Perform thresholding with selected min and max values
mimics.segment.threshold(mask=mask_a, threshold_min=1250, threshold_max=2650) # thresholds are set in gray values
# Fill holes in the segmentation mask
mimics.segment.fill_holes(mask_a)
# Create a point that will be used fot the region growing operation
point_1 = mimics.analyze.indicate_point(title="Region growing point",
message="Please indicate a point on the part of interest")
# Region growing. The original mask is preserved
mask_b = mimics.segment.region_grow(point=point_1, input_mask=mask_a, target_mask=None, slice_type="Axial",
keep_original_mask=True)
# mimics.data.points.delete(point_1)
mask_b.name = "Segmented right femur"
# Perform the boolean operation ""Minus"" to take the anatomy of interest".
mask_c = mimics.segment.boolean_operations(mask_a=mimics.data.masks.find("Lower limb"),
mask_b=mimics.data.masks.find("Segmented right femur"), operation="Minus")
mask_c.name = "Pelvis and left femur"
# Calculation of the 3D parts
part_a = mimics.segment.calculate_part(mask=mimics.data.masks.find("Segmented right femur"), quality="High")
part_b = mimics.segment.calculate_part(mask=mimics.data.masks.find("Pelvis and left femur"), quality="High")
# Smooth 3D parts
objects = mimics.data.parts
for part in objects:
part.visible = False
smoothed_part = mimics.tools.smooth(object_to_smooth=part, smooth_factor=0.6, keep_originals=True)
smoothed_part.visible = True
# Export the STL
mimics.file.export_part(object_to_convert=smoothed_part, file_name="C:\MedData\\" + smoothed_part.name + ".stl")
# Save the project
mimics.file.save_project()
